'95 Evinrude 90hp difficulty starting
npete79
I have a 95 Evinrude 90hp that has difficulty starting. This doesn't happen all the time and I cannot find a pattern. It happens both from a cold start and when the engine was shut off less than 10 minutes. Other times it starts with no difficulty at all. Once started it runs smooth, with plenty of power. Any suggestions as where to start to find a solution to this problem?
tashasdaddy
Re: '95 Evinrude 90hp difficulty starting
are you flooding it with the primer? pushing in on the key. what exactly is your starting procedure?
npete79
except for the first start, just turning the key. no priming or pushing in of the key
