74 402 jet.It getting hard to pull start.So will a little fluid hurt the motor?, It runs great. also i found in the bottom part of the housing a 1 inch return spring and i don't know where it goes.Any help will be great
use only premixed fuel to spray into the carb. starter fluid removes the lubrication and burns tooo hot. it is time for carb cleaning and rebuild kits.
