Re: 4.3 vs 3.0 fuel economy?
My Ecu has actually not been re-tuned at all.
I'm running the stock astro-van Fuel maps and Cam profile.
I basically dropped an astrovan motor into my boat, swaped the starter and alternator for marine one, and made a custom wiring harness using the astrovan harness.
I'm using all the stock automotive sensor, including the MAF, and simply did not connect the o2 sensors.
You can still plug an obd-2 scan code reader into the harness and read the automotive codes.
The engine starts, idles, and pulls perfectly. Great fuel efficiency, and lots of top end power.
The actual fuel maps for a marine application are virtually the same anyway, especially for an MAF based system.
The MAF sensor measures the air entering the engine, then the fuel "maps" are just basically to set the air-fuel ratio and the ignition timing.
More primitive EFI systems will rely only on MAP sensor inputs. This makes the fuel tables much more critical, as you are essentially estimating how much air your engine will be drawing in based on absolute manifold vacuum. If you change your intake, exhaust or cam profile, the ECU will not correct for it, and your A/F ratios will go way out to lunch.
If you took a MAP only EFI system from an automotive application and dropped it in a boat, it would run like crap.
What I would really like to do is drop a 6.0L v8 from the corvette or trailblazer SS into a boat, but nobody makes manifolds for them that work with a Bravo-1 leg
Those are LS series V8's, rater for 400 HP and 400 ft/lbs of torque. I bet they would make 450 HP in a boat, no problem (improved intake and exhaust)
Here is the closest engine GM marine has to the corvette engine....
http://www.gm.com/experience/techno...s/specialized/marine/2010_6000_LY6_Marine.pdf
They would likely get the same mileage at cruise as the 4.3 aswell... More efficient heads and combustion chambers, higher compression ratios..... better intake manifolds....
