Re: 93 Yamaha buzzer
First thing to do is pull the temperature sensor and use the ohm setting on a multitester to find out if it is working right. The sensor should show infinite ohms [total resistance] as long as it is cold. If it suddenly shows no resistance between 205-219 degrees fahrenheit [use a meat thermometer in a pan of boiling water], then it works correctly.
If it tests out right, you can pull the thermostat cover, remove the thermostat, lower the engine into the water, and start it up. If exhaust comes out of the thermostat cover along with water then you probably have a blown head gasket and/or a blown gasket in your exhaust. If no smoke, then you need to replace the cover and run the engine without the thermostat. If the siren doesn't come on, then buy a new thermostat. If you install the new thermostat and the horn comes on again...then remove the thermostat. Just operate without one. You will need to remove and clean your plugs now and then, but that is a hell of a lot cheaper than rebuilding the power head~
