Hello,
This is my first post to this forum, I have read lots of posts and searched this site many times. Now I have a question.
I have a 1966 40 HP Evinrude Big Twin 2 Stroke and I recently replaced the impeller and after starting this motor up How much water should be coming out the spout?
Here is a video of the motor running.
http://www.youtube.com/watch?v=FuAnNpCGJ_U
If I give it half throttle should it be a Steady stream?
Is that a normal amount of water to be coming out? I did not check which way the splines were on the original impeller and this is my first time starting the motor so I do not know how much should be coming out of the motor. I just want to make sure that the motor does not over heat in the middle of the lake.
Thanks
