  #1
Old April 18th, 2009, 07:03 PM
deeman7777 deeman7777 is offline
Default Evinrude fuel pump issues
When I prime the fuel line, gas sprays out of the fuel pump where the cork gasket is.
This motor is brand new to me - 1968 9.5 evinrude.
The motor also needs to have the fuel bulb pumped or it will die out.
I disassembled the fuel pump and did the blow test and could not blow into either port - I know you're supposed to be able to pass air through the intake port. I may have reassembled it wrong - or maybe it's always been like that....I did not test the pump with the blow test prior to taking it apart.
I found some great info on the fuel pump here and the assembly directions - but thought I would throw this out there to see if all 3 of these symptoms can help someone make an assessment.
Many thanks!!!
Mike
  #2
Old April 18th, 2009, 07:13 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Evinrude fuel pump issues
i would be done with it and replace with this: http://www.iboats.com/Sierra_18_7350...view_id.174139
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old April 18th, 2009, 07:23 PM
Rick. Rick. is offline
I'm sure I've read here at Iboats there is not repair kit available for the 9.5. I'm not sure this is a bad thing though. You should just get a new pump and have the peace of mind that it won't be giving you any thing to worry about. You say yours leaks, have you tried tightening the screws? Best of luck. Rick.
  #4
Old April 18th, 2009, 07:30 PM
F_R F_R is offline
It is very common for those things to leak. It may be the cork gasket is shot, or the plastic cover is cracked (common). Both are available from your Evinrude dealer. Either one will cause it to die out because it is sucking air through the leak instead of sucking gas from the tank.
However, you took the pump apart. So, there is no telling how bad you screwed that up.
  #5
Old April 18th, 2009, 08:03 PM
tx1961whaler tx1961whaler is offline
...and replace the fuel lines while you're at it.
  #6
Old April 20th, 2009, 02:50 PM
F R - you nailed it. Upon closer inspection the filter housing was indeed cracked which is why (I suspect) the fuel was shooting out near the cork gasket.
I ordered the Sierra replacement fuel pump. Upon further research, I learned that this is not a perfect fit and needs to be modified to work in the tight quarters under the hood of the 9.5.
I will research the options for installing the Sierra fuel pump and hope it solves the issue.
Thanks all!!
I will be sure to post a reply to let you know what I found.
Mike
  #7
Old April 20th, 2009, 06:18 PM
Please do. I have a 9.5 with a pump that I'm sure isn't omc but I don't know who made it. Rather than the brass thumb wheel with a flat screwdriver slot it has a small allen wrench bolt. I'm interested in how yours is going to fit. Rick.
  #8
Old April 23rd, 2009, 01:59 PM
Hopefully I will get advice on this question rather than starting a new thread.
I ordered and received my new Siera fuel pump.
Just for kicks, I tired blowing into the inlet of the pump and could not. I tried really hard, almost popping my ear drums and heard a really short duck call sound - I suppose the diaphram vibrating.
Should I be worried that the pump does not pass the blow test?
Thanks!
  #9
Old April 23rd, 2009, 02:19 PM
there is not a blow test, it has a diaphram that pumps fuel. filters are blow thru.
__________________
FLORIDA GATORS
TEBOW Country
  #10
Old April 23rd, 2009, 02:40 PM
F_R F_R is offline
The duck call sound was air passing through the check valves...which it should.
  #11
Old April 23rd, 2009, 07:11 PM
So if you blow on a fuel pump it makes a Duck sound. Wonder what sound a duck would make? Boy am I off topic! Rick.
  #12
Old April 24th, 2009, 09:51 AM
Wow! thanks again for the helpful info.
I am basing the blow test on the last statement on the popular reduild site as described below:
Fuel Pump Test
(23) You SHOULD be able to blow thru the pump by blowing into inlet (A). You should NOT be able to blow thru the pump by blowing into outlet (C).
If the pump does not pass this test, disassemble pump and check the parts that must be in an exact position or must be in an exact relationship to other parts.
This is from:
http://www.sschapterpsa.com/rambling...g_fuelpump.htm
Am I missing something here?
  #13
Old April 27th, 2009, 11:49 AM
Thought I would update the thread to help those in the future with the same issue.
The Sierra 18-7350 Fuel Pump DOES FIT WITHOUTH modification or disassembly and reassembly. Mine fit, with the arrow on the pump pointing up with out any mods at all.
I pumped the bulb - which went soft previously after a short time and it quickly firmed up and stayed firm. Motor started up and purred like a kitten. I hope I don't jinx myself now!
I had it in a tub and she ran just fine.
I took some pics and video and will post them later on. I am anxious to test it on the lake.
Mike
  #14
Old April 27th, 2009, 01:07 PM
tedstevens tedstevens is offline
Well i rebuilt my carb with the help of this forum last week. And i took apart my fuel pump to try to clean it out. And i must of messed something up because now i have to continually prime the bulb to get my 1971 9.5 evinrude sportwin to run. So i guess i should buy one of these as well? Or should i just try taking my current fuel pump apart and putting it back together again? I dont know how old it is? It came with the motor when i bought it off of craigslist two years ago. http://www.iboats.com/Sierra_18_7350...view_id.174139
  #15
Old April 27th, 2009, 11:02 PM
Quote:
Honestly, I don't try to rebuild the pumps anymore. I figure a new one for 50 bucks will probably last at least 20 years, since the original lasted at least that long.
  #16
Old May 6th, 2009, 09:44 AM
Here are some pics and videos of the motor. I hope this is helpful to others in the future.
Here is a video clip of the outboard running:
http://www.youtube.com/watch?v=-pApEz8xpBw
Here are some pics of the new fuel pump installed without any modifications.
http://i27.photobucket.com/albums/c1...Picture138.jpg
http://i27.photobucket.com/albums/c1...Picture137.jpg
http://i27.photobucket.com/albums/c1...Picture136.jpg
  #17
Old May 6th, 2009, 03:39 PM
film495 film495 is offline
I was also looking at either replacing or rebuilding a new fuel pump. This link is the OMC instructions on how to put it back together. Maybe it can help you.
  #18
Old May 7th, 2009, 10:06 PM
Glad your new pump fit. Your motor looks to be in real good condition. Have you checked compression. I'd like to know what it is. Rick.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1999 Volvo 5.7 GSI fuel pump issues shanayney Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 January 19th, 2009 10:58 PM
97 150 faststrike fuel pump issues Nitro Rick Johnson & Evinrude Outboards 4 August 3rd, 2008 11:06 PM
Fuel Pump Issues Spare_Time Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 27th, 2008 12:33 PM
2006 60hp EFI Fuel Pump Issues?? mnfishing Mercury & Mariner Outboards 3 June 25th, 2008 10:36 PM
fuel pump issues battery Johnson & Evinrude Outboards 18 July 25th, 2006 07:05 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
