Seadooman03
- Jan 31, 2009
- 48
1997 glasstron, 19.5......decent boat, just wanted to remodel it a little. So, i remove the interior, needed to reupholster a few panels, and seats..no biggy. Well, at this point, i said to myself, might as well just go for the full remod. So, I start to take out the carpet...pita....i remove the carpet, inspect the floor. It is slightly damp due to having the cover torn off of and letting it set in the weather. Floor doesn't seem rotted, not sure really how to check, doesn't flex except above the gas tank, which i removed that piece anyways.
Now, the deck, in the center of the back portion of the boat (behind the seats), the right and left side BOTH have a slight rise in them, bumps if you will. Not sure if that's normal? Now, in the the very back of the boat, the engine compartment there is also a big rise on one side, and not on the other? Ill post pics...shortly...
Any insight would be great...thanks in advance..
Kris.
Kris.
