Hello Everyone,
I've recently bought a v4 sea horse and it's overheating. I think there'e a problem with the joint between the water pump housing and the 2 tubes which lead up through the middle leg section. The tubes look like copper plumbing tubes, and they have whitish plastic fittings on the ends - one of these seems to have ridden up the tube and is difficult to get at, the other has come off and the end of the copper tube is showing - looks a bit rough. Does anyone know what I'm looking at here - I'm a newbie and don't know how the tubes should be connected to the pump. Also if I run the engine in a big water tank where should I look to see the water coming out?
Thanks for any help!!!
