stevenj
- Jun 8, 2008
- 156
I have an opportunity to purchase a 1960 40 h.p. evinrude with controls
for $125.00. with controls. says lower unit needs resealed, that a mech. told him that after tilting motor up and having oil run out of it.says block was replaced 3 years ago, I assume whole powerhead.If I go look at this motor I will take a stand ,tank of fuel and test drum with me (2 hour drive)and a good battery. I will check compression and try to start. my question is that I
have a donor 35 big twin 1956 and am wondering if the lower unit from the 30 will work on the 40. I also have a running 35 1957 that I made into a long shaft last year and those lowers were interchangeable.what other concerns if any should I have or check on this motor to help with my decision or negotiations on thes motor?
thanks ,steve
thanks ,steve
