Re: Stupid Type 1 Carb Question
U-Turn, I've been following your posts. I have the same motor, a 1973 Rude 65HP. I just got back from running my Sea Level boat at 6500 and then 7800 feet during a 3 week vacation. I spent the first 2 weeks trying to make it actually run, It was my first time opening up the carbs, where I learned that I had fixed orifice's instead of adjustable needle air/fuel fuel/air mixtures. My only option was to order a propeller from nevada (100 miles from where I was, but the only option). I changed from 13-3/4 17Pitch to a 14" 13Pitch and at least my boat was able to fish from, I couldn't Idle worth a damn but I fixed that by dragging 2 5gal buckets from each corner to obtain the 2.2 MPH that was better than the 4MPH that it would barley run at, any slower and it would die.
Anyways, I did pull my idle orifice's and mine we 32's. Of course back down at Sea-Level it seems to run okay. But I spend the 3-4weeks up in yosemite area and fish from 6000 to 9000 feet, so I plan on getting a few different jets, I have the stock 32's (and whatever is in the high orifice) with the 17pitch for sea level, I guess I am going to use the 13pitch for 3000-6000ft and need new idle/high orifices, then also going to need to get a 3rd prop and idle/high jets for the 6000-10000ft.
Anyways, can you explain to me what you got, how it helped? And maybe part numbers for the 33, 34, 35, 36 idle fuel jets? as well as the matching high speed fuel jets?
Thanks in advance, I had one other question, all three of my carbs are stamped 322292 on them? What are stamped on your carbs? The numbers were on the throats just under the butterfly linkage, can you please check yours?
Thanks in advance.
-John
