I'm not sure what would cause my main fuse to blow? sometimes it will start other times it blows the fuse. It's a mini 20 amp fuse. Any ideas where to start...
Re: Mid eighties 48 hp evenrude blowing main fuse often??
it just works the starting circuit. if you have anything else on it. remove it. could be igntion switch shorting out, or insulation cracked and wire shorting.
