Got a 225 Evinrude that I need some assistance with.
I want to say the powerhead is from a year before the ficht system but the lower unit is from a 99 225.
I say this because of the fuel pump and also because it is carb'd
The problem is that the motor is only turning around 3500rpm after the boat gets on plane were it should be turning 5000+rpm.
Done the same thing with 2 different props on it.
I have checked all the cylinders for spark and thats good
I took off the carb cover and it is shooting fuel into the carbs when I rev it up.
The boat will only rev to around 5000rpm out of the water.
What do I need to check on it next? I believe it is possibly a fuel problem.
It has a VRO pump on it with the oil injection disconnected and the fuel is now premixed in the tank.
Thanks
Thanks
