trim motor stuck
chrisjocoy
my outboard motor will not go up or down help. i cant find the manual release
83 mercury 150hp
QC
Re: trim motor stuck
Chris, I moved this over to the Mercury OB repair section where you should get more specific help. The other section is for propeller discussions . . .
Welcome aboard iboats, you've found the right place to solve your problem. Be prepared to supply lots of info. The more specifics, the better the answer. Good luck! :)
saumon
When looking at the PTT unit, the manual release valve should be on the right side at the bottom; you acces it through a hole in the engine bracket.
