  #1
Old April 15th, 2009, 07:00 PM
Darren43 Darren43 is offline
Cool 1995 225 Evinrude Big bore looper spitting out of #5 carb
I just rebuilt a 225 evinrude looper and had a sleeve put in cyl # 5 the sleeve did not have the small hole above exhaust port.engine has more compression on cyl 5 and spits back thru carb at Idle.Is the reason it is doing this because it didnt have this hole in sleeve.The man that put sleeve in said it wouldnt matter and I took him at his word.
  #2
Old April 15th, 2009, 07:19 PM
daselbee daselbee is online now
Default Re: 1995 225 Evinrude Big bore looper spitting out of #5 carb
OOOhhhh...not good.
That's a finger-ported looper and depends on all the little ports and holes for proper operation.
Those posts and holes in the sleeves match up with the holes in the piston skirt.
Not good.
  #3
Old April 15th, 2009, 07:39 PM
Faztbullet's Avatar
Faztbullet Faztbullet is offline
Its ok, the little hole above exhaust port is a compression relief, which do not come drilled in replacement sleeves, machinist must drill this after installation.This will not cause it to spit out carb. Check the reed block for a bent leaf or being held open by a piece of debris. Also check the reed block gasket. I plug my customers reliefs with set screws if they want the extra compression as it add about 10psi.
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
  #4
Old April 15th, 2009, 08:08 PM
Wow...great. It is good to know. I am glad he doesn't have to oull it all apart again.
  #5
Old April 21st, 2009, 11:02 PM
Question Re: 1995 225 Evinrude Big bore looper spitting out of #5 carb
correction it was spitting out # 6 carb .I was forgetting they cross.It had a reed gasket bad.now it spits out exhaust.it is running lean at idle on cyl#2 spits out exhaust until I cover part of carb opening on carb # 2.which is making it run richer and it idles great then . removed carb cleaned ,no difference .adjusted screw in carb ,no difference. Im stuck.I know its lean but dont know how to fix.Any help would be appreacited.
  #6
Old April 21st, 2009, 11:54 PM
Faztbullet's Avatar
Either the cover plate on side of carb is leaking or o-ring seal on rear of carb is damaged or leaking. The air idle screw should be about 5 1/2 turns out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Big Bore Looper Carb Question DUKE1 Johnson & Evinrude Outboards 3 March 1st, 2009 10:03 AM
Small bore vs Big bore pnwboat Force & Chrysler Outboards 6 June 8th, 2008 01:36 AM
1986 140 Small Bore to Big Bore irdir Johnson & Evinrude Outboards 3 April 5th, 2008 11:24 PM
1995 40hp Evinrude Spitting water with Exhaust wheresthefish Johnson & Evinrude Outboards 6 February 17th, 2008 10:55 AM
1990 Evinrude 200 hp Big bore Looper RetNav Johnson & Evinrude Outboards 4 September 5th, 2003 04:57 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
