  #1
Old April 13th, 2009, 08:05 PM
godwjw01 godwjw01 is offline
Default 1963 mercury 1000 100hp 4 cly water pump change out
ive got a 1963 mercury 1000 100 hp 4 cyl im trying to change the water pump out but i cant get the lower unit off . i took off the bolt in the front then the two on top then the two the two on the bottom then the one ovove the zinc plate but it wont budge its in nuetral am i missing any thing????Please help!!!!
  #2
Old April 14th, 2009, 04:56 PM
Doug Redinger Doug Redinger is offline
Default Re: 1963 mercury 1000 100hp 4 cly water pump change out
I have a 1963 850 Merc inline 6 cylinder that should be the same as yours if the year is correct. Although I thought in 1963 the Merc 1000 was also a inline 6 cylinder. I believe mine also had just the six bolts holding on the lower unit. The one in front on top, the two behind that on top, two on the underside of the ventilation plate, and finally the allen screw that holds the trim tab on. Although you might look up in the trim tab area to see if there is another bolt going up into the driveshaft housing. Its been a few years and I can't remember accuratelly. Corrosion may be holding the drive shaft, shift shaft or the water tube in place. Try shifting gears with the shift lever. Also try to slowly spin the motor over with the manual starter to see if it will jar loose the drive shaft from the powerhead. Just make sure the ignition is off. It's also a good idea to remove the propeller just in case. It might be alot easier if you get someone to help you. I use a rubber mallet to give the lower unit a whack.
I also use a heavy duty rubber bungee to hold the lower unit to the drive shaft housing so it doesn't drop off unexpectadly and break a housing or something. Good luck!!! If you do get it off remember to lubricate the splines on the driveshaft and the shift shaft before reassembly.
  #3
Old April 17th, 2009, 03:31 AM
Davesspeed Davesspeed is offline
I would be careful about hitting the cavitation plate with a rubber mallet, you could break part of it off. Try driving a thin gasket scraper between the gearcase and the exhaust housing about 2 inches from the rear. if it starts to seperate, work your way forward.
The stud that faces upwards in the front can get packed in with salt. If it seperates in the rear and seems to pivot in the front, the front stud could be packed in. More than once I had to cut through the exhaust housing to cut off the stud slightly above the gearcase to pry it loose. If you leave enough stud once the gearcase is removed you can use a torch and vise grips to remove the stud and replace it.
  #4
Old August 17th, 2009, 08:19 AM
chopo chopo is offline
[quote=Davesspeed;2047644] Try driving a thin gasket scraper between the gearcase and the exhaust housing about 2 inches from the rear. if it starts to seperate, work your way forward.
uh no, sorry Davesspeed. you should never ever drive anything between 2 machined surfaces. i dont know much about marine things but I do alot of auto work. I have seen alot of that done. and the fix was always large amounts of peratex junk. not a pretty fix and yes in does add some "meat" to your tolerances. just my 2 cents
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
alternator wiring for 1969 Mercury 1000 100hp robertwandersen48 Mercury & Mariner Outboards 2 September 12th, 2007 05:24 PM
1964 Mercury 1000 25th anniversary 100 hp water pump change? IceFire Mercury & Mariner Outboards 2 February 26th, 2006 03:09 AM
Fuel pump check valve orientation - 1963 Merc 1000 bh357 Mercury & Mariner Outboards 1 March 25th, 2004 04:20 PM
1963 100hp water from exhaust not telltale bh357 Mercury & Mariner Outboards 4 August 29th, 2003 09:59 AM
How to change water pump Evin. 100hp 88' laparm Johnson & Evinrude Outboards 2 August 18th, 2002 08:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
