lowkee
- Dec 13, 2008
- 1,890
Engine is a 1990 3.0L (Alpha 1 Gen 1) with good 'ol points ignition.
Okay, so I had to remove the rotor assembly in order to tighten a starter bolt and, in the process, lost track as to how the rotor was aligned.
Assuming no points of reference, how can I go about getting the timing close enough in order to get it started and use a proper timing light?
I've gotten it to pop and wheeze, but that's about it. I figure I'll ask here before I break something.
FYI, I have the manual, so references to it won't be lost on me.
Thanks guys.
PS: Which sid eof the engine is the 'front'? Towards the water pump? The manual doesn't specify. Also, am I correct in saying the #1 cyl is at the water pump?
Thanks guys.
