updated!!!!!problem remembering big sping placement
lizardfish
serial#A955266 carb#wmc113505, have no clue where to order a carb kit from,,does oreillys sell them? i dont even know how many strokes it is. 2 spark plugs i do know that.
can anybody post a illustration of the float and little needle thing placement? i cant remember if the needle points up or down, and if the big spring go's along with it
lizardfish
Re: need things dumbed down carb kit
1986 25hp
ifixf18s
dont know if its a 2 or 4 stroke? do you have to mix oil in the gas? If so this is a 2 stroke. Have you looked online for a carb kit, The S/N's should help you find the right kit.
lizardfish
Re: updated!!!!!problem remembering big spring place ment
ok i cleaned my carbs am now putting it back together im at the float part, i cant remember if the needle points up or down, and the big spring placement, can anybody post a illustration ?,please
ok,, i ate a sammich and thought about it,, carb kit complete started first pull.. in the morning will be the true test... thank you all
