lizardfish
- Mar 6, 2009
- 40
ok i turned the mix 1/4 started right up,, i let it warm a bit then started pushing choke in gave it a lil rev sounded good,, pushed choked all the way in died after a min or two,, did same process over and pulled 5-6 before it started then started to push choke in and it died.1986 mercury serial#-0A955266- thank you 4 your help
