  #1
Old April 12th, 2009, 11:47 PM
z27651 z27651 is offline
Default 1976 Mercury 20 HP Stop Switch Wiring Help
I have a 20 HP motor that the stop switch is disconnected and I need help on how to wire it. I know the one wire goes to the ground and the other one goes to the control box some where but I can't figure out where. Serveral of the wires from the control box goes to the terminal block and there is one screw on the terminal block that is empty, is that where the other wire connects to? I spend last summer getting the motor to run and it is running great now, but I don't what to damage the control box by guessing where the wires go.
Thanks for the help,
Charles
  #2
Old April 13th, 2009, 09:21 AM
Laddies Laddies is offline
Default Re: 1976 Mercury 20 HP Stop Switch Wiring Help
Here's a wiring diagram that should help 73 to 77 are the same.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old April 14th, 2009, 12:09 AM
Thank you very much for the picture, I installed the switch tonight and it works great.
  #4
Old May 6th, 2009, 12:13 PM
theclassicboatman theclassicboatman is offline
Exclamation Re: 1976 Mercury 20 HP Stop Switch Wiring Help
I'm not sure if I'm posting this in the right place...but if someone out there can help me I'd be greatly appreciative. I've got a 1975 Merc 9.8-110 switch box that needs to be installed, but I cant seem to find a wiring diagram for this anywhere. It's a Mallory box if that helps; unfortunately the previous owner "already did the work" for me so there's nothing on the motor for me to go by. I could probably make a decent guess, but my fear is if I have something reversed (specifically the +/- leads to the coil) that it'll cause irreparable damage. If you could just point me in the right direction...
  #5
Old May 6th, 2009, 01:41 PM
First it's hard to get answers when you add on and ifnyou look at the 75 wiring diagram you will see the wiring is the same as the next few years model with the exception of the colors and I would expect a currenty part to have the new colors which meam you will have to use both diagrams to get it hooked up properly.
__________________
  #6
Old May 6th, 2009, 02:57 PM
onepingonly onepingonly is offline
Talking Re: 1976 Mercury 20 HP Stop Switch Wiring Help
Quote:
Laddies, Thank you so much for posting those wiring diagrams. I've been looking for them for a while. I bought a 1974 merc110 9.8 knowing the stop switch wasn't wired....now I can do it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 20 hp Switch Box test/diagnosis Longcrier Mercury & Mariner Outboards 1 December 6th, 2008 08:34 PM
need some help,1975 ,20 hp ,B2320,,,,wiring piperdog Johnson & Evinrude Outboards 0 June 1st, 2008 06:14 AM
Stop Switch install 1978 20HP Mercury OB FatBob78FLH Mercury & Mariner Outboards 2 October 29th, 2007 12:09 PM
1976 20 hp Mercury recoil problems Barney LeJeune Mercury & Mariner Outboards 1 September 25th, 2002 01:33 PM
Mercury tilt stop switch Neikensnest Mercury & Mariner Outboards 3 September 3rd, 2002 08:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
