I have just bought a non running Johnson 9hp 1979 and had 50psi in one cylinder and 65psi in the other, i could only eventually get it started and running on full throttle, renewed the head gasket as it was knackered between the bores and then i had 90psi in the top and still 50psi in the bottom piston. After a few attempts of running it, i tested the compression and the 90psi piston had dropped to 50psi matching the other piston. I have now given up trying to start it. Can anyone shed any light? I have spark and i must have fuel for it to run on full throttle, i know it has been stood for ages.
