Re: 2001 200 HP Mercury cracked powerhead
Sounds like piston seizure/wrist pin bearing failure and crank snatched wrist pin from piston boss. This is typical of efi as a bad/clogged injector will cause a cylinder to run lean. If it was a weak impeller the other cylinder will be scuffed. Do not install these part on replacement untill you have check and cleaned. A reman powerhead run $3800-5500 depend on supplier
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
