krisnowicki
- Jul 11, 2007
- 1,172
I had a probvlem with water intrusion in my gen II drive. The nipple were the oil is tranferred between the resivior and the drive was leaking and allowing water in. When I drianed the dirve it had ALOT of milky green oil. So I fixed the leak and ran it for about 20-30 mins today and. In the resivior there is a small amount of milky oil on top of the res. Like about .5 of an inch of oil kinda like a film.
Could it be this came from the oil mixing before and it was what was not out of the drive when I changed it? ( i drained it for an hour) or is this new water. Is it common to have residue mositure when this happens? The amount of oil in the water did not increase and ti showed up about 5 mins in the run. And it is nothing like what it was before.
Also, I drained a bit of oil from the bottom of the leg and it is pretty Mobil 1 and clear.
