I installed a new trolling motor mount on my Nitro 170tf boat. I had to drill new holes and I used new isolator bolts. However I left the old isolators (the rubber part) from my old trolling motor in there. Everything seemed to work fine except for one bolt. When you screw the bolt into the rubber part it not only doesn't get tight but when you remove the screwdriver, the screw loosens itself, i.e., it does about a quarter turn the other way. I was thinking maybe the rubber isolator part is getting twisted somehow. Any suggestions?
