  #1
Old April 9th, 2009, 05:21 PM
Jethros Jethros is offline
Default Yamaha hard starting when cold
I have a yamaha 2002 60hp with the electro thermal valve. it seems to work on the bench but can not figure out why it wont start the motor when activated. In the test it taks several minutes for it the be fully extended. Can anyone explain why it doesnt work instantly? If i use the emergency red lever it starts right up.
  #2
Old April 11th, 2009, 09:59 AM
Default Re: Yamaha hard starting when cold
  #3
Old April 11th, 2009, 07:36 PM
cousinabe's Avatar
cousinabe cousinabe is offline
check your carbs.
emergency mode is actually manual enrichment and would be used for a manual cold start or if the primer failed.
running only with the emergency on indicates a restriction in the pilot fuel circuit.
physically remove the main jet,pilot fuel jet and the emulsion tube and carefully clean them.
also make sure the transfer passage between the main well and the pilot fuel orifice is clear.
dont forget the rubber pilot fuel jet plugs.
  #4
Old April 12th, 2009, 06:03 PM
Thanx for the info. It did start right up now that I the pilot jets are clear.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hard starting, cold Billbo59 Johnson & Evinrude Outboards 2 September 17th, 2008 12:26 PM
Honda BF8 hard starting when cold. dvndog Honda & Tohatsu/Nissan Outboards 11 September 25th, 2007 10:39 PM
Hard Starting when engine is cold markwarren Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 24th, 2006 02:52 PM
Another hard cold starting problem ajc1219 Johnson & Evinrude Outboards 11 April 3rd, 2006 04:29 PM
hard starting 9.5 when cold wayne h Non-Repair Outboard Discussions 0 June 8th, 2003 07:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
