KickinBass23
- Feb 28, 2009
- 7
Hey there guys, I've got a 75 Delta, 14 or 16ft tri hull fishing boat. I have started tearing it down to extend the front deck back about 2 more feet for added space and storage. So, I am now at the point of no return... Anyway, I need to frame up this addition to support my weight and make it structurally sound. I will need to bond pressure treated wood to the inside of the hull for a starting point for the framing. Question is, what can i use to bond these two materials together? I know epoxy will bond wood-to-fiberglass, but what brand, where can i get it, and so on...what about wood-to-wood? I will be adding storage compartment doors to access the inside from the top. I need to devise a lip around the edge of the door to keep the door from falling inside the compartment. Any advice would be GREATLY appreciated, and i will try to post some pictures of the teardown ASAP.
Thanks
John
Thanks
John
