Bench seat Bass Boat Astro or Procraft
loghopper
I need a little help I need to remove my bench seat in my bass Boat it is a 200 Astro same as a Procraft . I tryed pulling up as hard as I can on the bench seat I could not move it . I need to take the bench out so I can have the seats recoverd or order new ones . Thank You :)
a70eliminator
Re: Bench seat Bass Boat Astro or Procraft
Probably have to remove the entire base to get at the screws underneath.
Ezekiel1
Just signed on the forum/new kid on the block...just checking the site out and saw your old post...had same trouble with mine...bench seat...each seat section has a smaller center square, pull up on the square...may be hard to come out at first if been there for a while...but pull on it, The little center will come out...underneath are the screws that hold the seats to the base. Hope this helps...I never could figure it out until someone showed me, just pull up on it, it is not held by anything...there are the screws...
Bob_VT
Answering a post that is over a year old is usually not a good idea....... we are usually quick to help but if people do not come back we let the post die.
Welcome to iboats!! We hope you enjoy it here..... we can just about guaranty that :D
