Re: Sliced through my HULL!!! 12 inches
Well i give it shot, first are you able to get at it from the inside? i'm guessing yes. what i would do is get a fiberglass kit from wally world or and auto parts store, cut you some peices that will fit through the cuts and portrude out the bottom, depending on how wide the cut is you may get two or three pieces ready for each of the cut like 2-12"x2" and 4 of the 4" long by 2" wide.
saturate those pieces in fiberglass resin and insert into the cut and push-pull it through half way so some is sticking out below and above let it harden and trim off flush, there may be some other techniques too like just applying masking tape to the bottom and pouring epoxie into the crack till full and let cure but not sure if that would be enough alone without any reinforcing material? There are probably many ways to seal it up and i wouldn't think structure support would be hindered, you could always lay some mat over the whole area inside afterwards. I any event don't loose sleep over it just continue on with what you were doing it's not that big a deal.
