  #1
Old April 8th, 2009, 10:23 AM
sam#1 sam#1 is offline
Default 1994 mariner 115 will not throttle down
Engine runniing great then I throttled down for no wake zone but would not go down to idle speed. All cables intact and quicksilver throttle is ok. When i bought boat (1st and only)was told by friends to have oil pump disengaged and add oil to gas tank, they told of having to rebuild engines because pump quit or oil stopped flowing and motor siezed. Now I have been told a shaft from pump may have dried and frozen causing carb butterflies to freeze halfway open prohibiting throttling down. Is this a possibility? I am a novice and disabled with very limited income, I shutter when i here 75 to 100 dollars an hour labor. Anyone have any answers.
  #2
Old April 8th, 2009, 12:59 PM
Laddies Laddies is offline
Default Re: 1994 mariner 115 will not throttle down
First, there is no shaft from the pump to the carbs. In most cases when the oil pump is disconnected the pump is remove then the pump shaft pulled out and the pump reinstalled. When you run premixed oil the throttle shafts are lubed the same as when the pump supplied the oil but in either case the shafts can stick in a corrosive environment, I would take some penetrating oil and squirt the shafts and try to loosen them up before doing anything else. Let us know if it takes more.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old April 8th, 2009, 04:55 PM
Lone Duck Lone Duck is offline
Make sure your throttle stop has not worked loose and preventing the carbs to close.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 Mariner 115 sschefer Mercury & Mariner Outboards 0 January 23rd, 2009 08:17 PM
1996 Mariner 115 HP Outboard trim won't go down from Throttle Switch fish2287 Mercury & Mariner Outboards 1 June 12th, 2008 05:58 PM
1994 115 Mariner Power Trim and Tilt issue Stripersonthebeach Mercury & Mariner Outboards 3 May 14th, 2008 04:12 PM
1994 Mariner 115 Trim Tilt wont go up COYOTE54 Mercury & Mariner Outboards 5 October 7th, 2006 10:47 AM
Throttle linkage on 1992 Mariner 115 hp BJM Mercury & Mariner Outboards 0 June 7th, 2004 03:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
