  #1
Old April 7th, 2009, 05:04 PM
Drewdaddy Drewdaddy is offline
Default Evinrude 9.9 stalling idle problems
Hello all, just want to make sure I am on the right track. This is the first engine I have ever torn into so I want advice before I tear it up. I have a evinrude 9.9 1987 that I bought and the owner said ran great . When I fire the engine up, it runs for 3 to 4 seconds then dies. Now if I during this time pull and push and pull and push and pull and push the choke off and on the engine will continue to sputter and run for sometimes a minute or more. Now I did the basics and checked that the fuel pump was indeed pumping to the carb. Then I took the carb apart and found alot of gunk in the bowl. I soaked the carb in seafoam for about two hours then proceeded to clean the carb out with cleaner and finally I blew it out with compressed air. After reinstalling the carb it does almost the same thing. I would say it seems to run a couple of seconds longer but not much. I have taken it back apart to let the carb soak overnight but wanted to see if there was something else to try. Also I tried the pump the primer bulb trick while the engine was running and that made no difference. Thanks for the help.
  #2
Old April 7th, 2009, 05:11 PM
Rick. Rick. is offline
Default Re: Evinrude 9.9 stalling idle problems
Have a look at the top of this forum, first item is called "Top Secret Stuff" Look in there for answers to your questions. How to clean a carb. How to set up the needle valves and more. From what you are saying your carb. could still be dirty and /or your slow speed setting should be a bit richer. Best of luck. Rick.
  #3
Old April 7th, 2009, 05:55 PM
By slow speed setting do you mean the adjustment knob on the front of the motor by the choke? I did adjust that alot if that is the knob. I tried it both directions and all in between. Thanks for the info.
  #4
Old April 7th, 2009, 09:19 PM
Yes that is your slow speed adjustment. If making that richer isn't doing it for you I think your carb. needs more cleaning. Rick.
edit. Also have a look at this link. I believe it is a "must read" for anyone with a 9.9.
http://www.sschapterpsa.com/rambling...OMC%20info.htm
  #5
Old April 7th, 2009, 09:48 PM
Wow that's funny, I found that website shortly after posting this message and found it very informative. Do you have any suggestions of where I might be able to find pictures of a rebuild on a carb? There are many posts telling me how to do it, but mentions things like the high speed adjustment and the low speed adjustment as expecting I am to know exactly where those are. I have a manual on the way so I suppose that will tell me, but it sure would be nice to see those pics now so I can identify all the parts. Thank you again for the response.
  #6
Old April 7th, 2009, 10:21 PM
tx1961whaler tx1961whaler is offline
If you go to http://shop.evinrude.com there are diagrams of the carb in the electronic parts catalog.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1995 Evinrude 200hp / Idle Stalling when Warm ericfebs Johnson & Evinrude Outboards 7 October 20th, 2008 06:09 PM
95 Evinrude 200 stalling at idle after running ericfebs Johnson & Evinrude Outboards 4 November 24th, 2007 11:42 AM
Evinrude 200 stalling and runs only at idle heflins Johnson & Evinrude Outboards 1 October 31st, 2007 12:55 PM
'73 65hp evinrude stalling at idle...Help! magicnov Johnson & Evinrude Outboards 0 September 4th, 2007 10:53 AM
96 70HP Evinrude, idle problems, how to ajust timing for idle???!!! (RickDB??) jimogeek Johnson & Evinrude Outboards 2 July 6th, 2004 05:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
