Re: starcraft american 76 with wakeboard pylon?
Check the floor and stringers carefully, as I haven't seen many that weren't at least somewhat deteriorated. Be sure to seal any screws that go through the floor. Also, the keel is dead center under the floor, so if you have a peg or anything that goes through the floor, keep that in mind. Not a good idea to drill a large hole into the keel as it will create a weak point...
Should be a good ski boat - they plane off quickly and have a fairly small wake for a V-hull.
- Scott
