Evin. 8hp pull cord stuck! URGENT!
newhawaiidude
late 90's evinrude 8 hp for a small inflatable boat type deal. test ran the engine...ran fine and great, idled a little low so i took off the engine cover and turned the idle up with one screw, 5 min job...and i was done. went to test run it again...pull cord is stuck in place, wont pull out even though i had just done it a few times 5 minutes before...its a friends engine, i feel bad and in a rush...HELP!!
thanks
Tim Frank
Re: Evin. 8hp pull cord stuck! URGENT!
There is a mechanical interlock that prevents starting (pulling the cord) if the throttle is too far open.
Seems like the adjustment you made put you over the top.
Back off that idle-adjustment screw to where you found it and you should be OK.
Mas
I hate to ask...but is the motor in neutral??
MAS
newhawaiidude
okay good deal, im gonna go try now...thanks for the quick reply...ill keep updatin-theres no neutral or forward or anything, just constantly running-if you think there is...where would it be located-im used to 55;s where its on the steer handle but theres nothing there....
Mas
Look for a lever on the left side just below the removable hood.
MAS
Tim Frank
????...:confused:
Tim Frank
MAS
He got it running to test it, and presumably did not shift out of Neutral or would know where the shifter was.
Mas
I do not know all the models of evinrude...but a '90s 8 HP should have a gear case...wouldn't you think? 8 HP is a lot of motor to not have a neutral!
MAS
Tim Frank
MAS
I have a 91 Evinrude 8HP.
Definitely has a shift lever, but on the right hand (starboard) side.
Mas
I guess that depends on which way you're looking, but I usually start my motors looking aft and that would put starboard to the left!
Point is, the guy has a shiftable gearcase and doesn't know it. It's very difficult to pull the cord while it is in gear!
MAS
