  #1
Old April 7th, 2009, 10:21 AM
stackz stackz is offline
Default universal gauges, tach and mercury engine?
ok, wanting to completely redo my gauge panel while I redo the wiring on the boat. its got old mercury quicksilver gauges and apparently people want like $100 just for the stupid tach.
I like all my gauges to work and match.
why the hell should I pay $100 for a stupid tach gauge???
I see teleflex sets go for $140. after adding in a few extra gauges I want, I should be at around $200-$230 or so AND they'll all be brand new....and look better.
anyway, what gauges should I look for exactly (ones that use mercury senders I would think) and how do I determine what type of tach I need??
so far tach wise I've just gotten pics of the front back and matched to my old one. no clue how to tell what pole I need, etc.
  #2
Old April 7th, 2009, 11:11 AM
Silvertip Silvertip is online now
Default Re: universal gauges, tach and mercury engine?
All we know is that you have a Mercury engine. Is it an outboard or an I/O, two stroke or four. It makes a difference what gauges you need.
For an outboard: Typical sets include Tach, Speedo, fuel, and voltmeter. Water Pressure and Water Temp are desireable. Water pressure tells you the water pump is working but does not tell you whether the engine is overheating or not. Therefore the water temp gauge is desireable. You need a temp sender for an outboard that matches the gauge.
For an I/O: Tach, Speedo, water temp, oil pressure, voltmeter, and trim. The outdrive needs a trim sender. The engine needs an oil pressure and water temp sender to match the gauges.
Fuel gauges are universal and require a 30 - 240 ohm fuel tank sender.
Tachs are universal for most outboards but you need one for an I/O if a universal does not support the I/O engine.
  #3
Old April 7th, 2009, 12:47 PM
sorry, 1988 M90 2-stroke 90hp engine
I want to get the following:
speedo/tach
voltmeter
trim level
fuel gauge
water temp/pressure
oil pressure
I was looking at the teleflex series gauges that use mercury sending units. I've got one of those magnetic 320ohm fuel level senders as well.
I'm just confused mainly on the speedo and the tach. speedo I have no clue how they even are set up. on cars you have a drive gear in the transmission and a driven gear for the sender (unless electronic)...on a boat...no clue lol.
also, the whole thing with the poles on the tachs...my engine is a 3-cylinder but all the tachs I read about say 2/4/6 cylinder??
  #4
Old April 7th, 2009, 12:51 PM
Chris1956 Chris1956 is offline
Stacz, no oil pressure in 2 cycle motor. If that is a inline six engine, it has no thermostat, so water temp is almost unusable. Motor likely has no trim sender, and no provision for one.
Stick with tach, Speedo, voltmeter, water pressure and fuel.
  #5
You have a two stroke engine -- there is no oil pressure! You also don't need a trim gauge. You can turn your head to see the engine. Your seat of the pants tells you what proper trim is. Besides, trim settings change depending on load. Trim gauges are primarily used on boats where you can't see the engine or outdrive (pontoons and I/O's).
  #6
Old April 7th, 2009, 12:56 PM
You are looking at the wrong stuff. Universal fuel gauges need a 33 - 240 ohm sender -- end of story. You need to change the sender. You are looking at auto style tachs which don't work on a two stroke engine. Two stroke tachs are universal and don't care how many cylinders the engine has as they work on stator pulses and can be set accordingly. Yours would be 6P.
A speedometer is not an electrical device. It needs a pickup (called a pitot) at the back of the boat. A small tube connects the pitot to the speedometer. As the boat passes through the water, pressure builds in the tube which makes the speedometer increase.
  #7
yeah but its got a trim gauge now as it is (sensor is on the pivot point on the engine) so I'd like to keep that.
I've gotten used to knowing the little spot on the trim gauge that keeps the boat perfectly planed and not leaning.
I figured there was no oil pressure on a 2-stroke but didnt know if there was something that went inline from the oil injection tank or not.
anyway, how do I determine what type of tach I need?? I've seen some that have like a million pole positions and some that only have 5-6 or so. this is my first time dealing with marine gauges so its my learning curve..
edit: 6P tach, got it.
edit #2: how did you come to the conclusion on the 6P (P=pole right?) just trying to learn for future reference.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
New Tach? Additional Gauges?? excalibur-oc Johnson & Evinrude Outboards 8 August 27th, 2006 08:19 PM
Are outboard trim gauges universal ?? MuskyHunterDave Johnson & Evinrude Outboards 7 February 10th, 2006 12:46 PM
Mercury (Tracker Boat) Gauges to Evinrude Engine Mike D Cincy Johnson & Evinrude Outboards 4 August 5th, 2004 11:11 AM
trim gauges on digital tach gator79 Yamaha & Suzuki Outboards 2 January 27th, 2004 01:37 AM
universal atomic deisel engine tuborg Non-Repair Outboard Discussions 1 May 17th, 2002 08:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
