  #1
Old April 7th, 2009, 12:55 AM
rothfm rothfm is offline
Unhappy New boat cover-boat very wet inside!!
Any Cover pros out there? sorry for the book, my wife says I talk too much!
I finally purchased Boat cover...My last post was for help "shopping" for one...But sad to say I need to inquire again about the new one LEAKING
Its been on the boat one day, went on dry now its pouring today.
Its a tie down trailer type on my open Dual Console 21'. Ok, Now that I've crawled in to see exactly what is going on with my new cover.....Its not just leaking at seams or stress points as I thought it might be. The entire underside of "ALL" areas of the fabric is wet. It then beads on the underside, then drips.....Just about all over.
Is this normal for what I thought was a decent cover? Its a Brand-New ProBass Shop "STEARNS" brand "stormpro" 600 Dernier poly cover. No Pooling and good fit. Its pretty taught, and I have the Trailer tongue raised very high, There is no pooling at all. Today it poured and I watched the cover carefully. At first it beaded up really well. But over time, in areas, I could tell the material "darkened" with moisture and didnt appear to be beading.
I know these are not high dollar custom covers, but Geeze! $200--Brand new and my entire boat inside is drenched? Will some water proofer applied truely help? Or should I take it back and try some other brand or material? I'm a long time boater but this is my first top. Take that Back--I Made one awhile back for my smaller boat, and that fabric was very waterproof. But I dont want to spend a month at the sewing machine again.
Anyone cover experienced have any thoughts?..Apply Waterproofer, or try another cover?
I just spend hours reading waterproofer posts, and looking at mfg websites. I'm leaning on trying one of them. I really like the fit, and look of this cover on my boat...Bummer.
Most appreciated.
Mark
  #2
Old April 7th, 2009, 01:03 AM
zach103's Avatar
zach103 zach103 is offline
Default Re: New boat cover-boat very wet inside!!
take it back.. get your money back
__________________
1986 Larson Senza V-175BR
1977 Columbian Celebrity 14'
  #3
Old April 7th, 2009, 01:04 AM
rentprop1 rentprop1 is offline
maybe you have it on wrong side out ?? and the repellent is on the underside ??
  #4
Old April 7th, 2009, 01:23 AM
bhammer's Avatar
bhammer bhammer is offline
Master Chief Petty Officer
I went through the same issues with my last boat. Bought a cover for it from Bass Pro Shops, put it on and the next rain, it did the same thing. When I talked to the BPS folks, they said that is because it breaths and water can eventually seep through. Bought some water repel in a spray bottle. That helped but would need reapplied every couple of months to keep it dry.
With my new boat, i bought a Westland sharkskin cover with a vent support. Of course, it was a lot more expensive than the BPS cover but it doesn't leak. I sprayed it with my hose for 30 minutes, then left the garden sprinkler on it for another hour. Completely dry inside. I have to say that I am impressed with Westland too. When I installed the cover, I noticed that there wasn't any reinforcements for the bow cleats. I emailed them and they are sending me the stuff to have it added. They even said that I could ship them the cover and they would sew them in for me. I will take to a canvas shop and have it done while keeping my warranty.
__________________
2007 Starcraft Limited 1900 RE
Mercruiser 4.3L MPI w/ Aplha
  #5
Old April 7th, 2009, 01:47 AM
bhile's Avatar
bhile bhile is offline
If you read the fine print a lot of those covers say "water repellent" and not "water proof". I went thru that to and wound up paying a lot more for one that was water proof.
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #6
Old April 7th, 2009, 03:36 AM
cr2k cr2k is offline
Send a message via MSN to cr2k
Most boats now days are shipped in shrink wrap. Check with your local boat dealer he may save them. Some do and some dont. You would then use your tight fabric cover as support for the shrink cover. You can put grommets in the plastic cover or use the poly tarp fasteners (kinda like a garter and stocking clip). Then you have both a shade, sun, dust cover and a rain cover. I do wonder if the moisture is from water wicking thru the fabric or condensation form moisture in the boat. You might a try a vent. As you said it was wet all over the bottom I am suspecting condensation.
  #7
Old April 7th, 2009, 09:48 AM
krakatoa's Avatar
krakatoa krakatoa is offline
Cmon guys!, a boat cover is to maintain water and dirt OUT! My friend, send your cover and ask for a refund....
__________________
Boricua 100%
  #8
Old April 7th, 2009, 09:55 AM
Silvertip Silvertip is offline
I also agree that some of the problem is due to condensation. $200 is not alot to pay for a cover. Some materials serve more as a sun shade than to repel water. Spraying the cover with a silicone tent water proofer will help, especially the seams.
  #9
Old April 7th, 2009, 10:03 AM
rrhodes's Avatar
rrhodes rrhodes is offline
Take it back.... Spend a little more money on a good cover. It is a small price to pay to protect your investment.
__________________
Rick
2008 JC Neptoon 25TT
115hp Honda 4-stroke
2007 Suburban LTZ
Lake Murray, SC
  #10
Old April 7th, 2009, 10:11 AM
cranksbait cranksbait is offline
Take it back for sure. I bought a Hurricane cover from Canadian Tire for less than $200.00. I left my boat out in the torrential downpour for three days and my boat was bone dry. Until I slipped and dumped the pooled water into the boat. I've had this cover for over a year and it has never failed me. I even left my boat out exposed all last winter with just this on it.
  #11
Old April 7th, 2009, 10:21 AM
Wassachu's Avatar
Wassachu Wassachu is offline
I had the same problem years ago. I tried spraying water repellent it but that slowed the leaks down but didn't stop it. After awhile green things started growing inside the boat. It stayed wet too long. No air circulation. Take it back before you have bigger problems. I went to a cheap tarp to cover the boat. This gave me protection from the sun and debris but some moisture still got through. There was enough air circulation that the boat dried out quickly after the rains stopped. As long as I kept the tounge high and plug out, water didn't fill the boat. The cover had to be replaced after two seasons.
  #12
Old April 7th, 2009, 04:19 PM
Mark42's Avatar
Mark42 Mark42 is offline
A good tarp is considerably less than the custom fit boat covers, and do not leak. A tarp, a few tarp clips, and a set of bungie cords and a PVC pipe frame will keep the boat dry.
__________________
1985 Bayliner 1600 Capri Cuddy, 1965 MFG Niagara Custom. >> MFG Video<<. >> MFG Project<< >>Bayliner Hard Top Project<< >>Bayliner Fuel Tank Project<<
  #13
Old April 7th, 2009, 04:28 PM
Expidia's Avatar
Expidia Expidia is offline
Send a message via Yahoo to Expidia
Take it back. Most online shops are now carrying a lot of crap from China yet under brand names.
A cheap tarp from Harbor freight will do a better job then the one you have.
Buy a decent cover (check iboats) and if it does not come with the two poles and vents put them in yourself. These are cheap and easy to install in any cover. They circulate the air and prevent mildew and mold.
__________________
2007 Lund 1425 Classic SS
2007 40 hp Merc 4 stroke EFI ELPT
http://s198.photobucket.com/albums/aa2/expidia/
Sometimes you eat the Bear and sometimes the Bear eats you!
  #14
Old April 7th, 2009, 04:44 PM
Biggems's Avatar
Biggems Biggems is offline
I recently bought a cheapo boat cover from Walmart for $60 and it's held up great. After our last big rain, I went out to check on the boat and the frame I had rigged under the cover had collapsed, so there were two huge pools of water. I emptied the water then took the cover off and checked the boat. It was bone dry!
You can get a good cover without getting your wallet raped. I used a tarp before the cover and it worked well but I couldn't get one that was the right size to make it taught all the way around.
If there is alot of humidity where you are, condesation would be the best explanation besides that cover sucks.
__________________
14'6" Northwood 1467LW---Work harder! Millions on welfare are depending on you!
  #15
Old April 7th, 2009, 04:52 PM
graydawg graydawg is offline
I had a shoremaster on my yarcraft and it held up great during the 3 years I had the boat. Bought another when I traded boats and I thought the price was reasonable.
  #16
Old April 8th, 2009, 09:51 AM
Thanks everyone for the input. Its definetly just seeping through the material. I"m going to take it back to PBS today and order either the SharkSkin by Westland or the Endura by Carver off the iboats site and they that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
do I cover my wet boat after use?? cruisetricia Boat Topics and Questions (not engine topics) 8 June 3rd, 2008 09:54 PM
New boat owner help needed, wet foam rotten floor, rebuild started pictures added! joelaurencemk3 Boat Restoration and Building 17 April 30th, 2008 04:54 PM
New Boat Cover Gary H NC Boat Topics and Questions (not engine topics) 5 August 28th, 2007 11:27 AM
New to boat ownership; some Q's inside! acex008 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 11 August 16th, 2007 10:58 AM
new boat cover by gulfstream lonewolf5347 Boat Topics and Questions (not engine topics) 0 May 24th, 2003 03:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
