pkrainert
- Jul 27, 2008
- 196
My 77 rude is running a little rough latley. What should I do to fix the problem? I am considering rebuilding the carb, changing the spark plugs and lower unit oil while im at it. What else should I look into? Should I do a de-carb with some seafoam?
Also it seems a bit louder than most other motors I have seen around here that are around the same age and size. what would cause this?
