Re: Inverter power supply
I considered relay's, but I can't find any SPDT's any larger than 40a.
I keep going back and forth in my mind: the inverter is 30a CB protected, but is hooked directly to the bat...but the same inverter can be powered thru a cigar lighter outlet...but the bat has 800a+ available...but it's only a 50a alternator...
I've thought myself into a circle. If it were my truck, I'd wire it directly to the bat and have a nice day. In the boat I want it switched from the helm and CB protected on both the switch leg and pole sides.
Sorry guys, I'm just a little fuzzy on this one.
Why do you need SPDT?
If the inverter os 30A, you should provide a circuit that can deliver continuous 30A.
A start solenoid (SPST) will indeed fail after a few seconds, as noted previously, so is not an adequate setup. It is designed for intermittent operation. The latching coil would fail.
The cigar lighter feed is for those applications that will not tax the system; the cig outlet circ protection would blow to save the wiring before even approaching the capacity of the inverter you mention. Obviously the cig outlet could not handle the amps you suggest.
The alt has NOTHING to do with it.
Just because the batt has a lot of amps available does not mean you need to size the conductors or circuit for that. The drinking water system from Niagara Falls does not need to accommodate the flow of the falls.
You do need to design for the amps used, and for the duration of the switched connection. How many amps, and how long?
Better to run proper marine grade wire with appropriate circuit protection. A Marine grade Ckt Bkr is available for your application. Use it as a SPST setup, eh?
