4.3L engine compression
Faerbairn
Here are the compression numbers. Any ideas what is causing the 95? Could the valves be slightly open or carbon build up?
#1 150psi
#2 160
#3 160
#4 95 ??
#5 145
#6 130
Thanks,
Adam
JustJason
Re: 4.3L engine compression
Could be the valves... could be the rings.... could be a head gasket.... only way your going to find out for sure is to do a leakdown test.
mthieme
You could a wet test to narrow it down from lower / top end.
JustJason
eagh..... a wet test does nothing more than load the compression gauge full of oil.
IMHO :)
Faerbairn
Thank you for your input. How do I do a leak down test?
Thanks..
iang
Ex Riser leaking onto No 4 valve causing it to rust and seat badly???
