sandpiper_38@hotmail.com
- Feb 21, 2009
- 1
I am on a circumnavigation and have had many problems with my Suzuki 2.2hp. When there is a spark I receive a shock when I touch the cord, that is when it is running. Other times it decides not to spark at all and will not run till I jiggle the spark cable around. I have done everything I can to this engine to keep it running, I even cut the spark wire that was shocking me when I touched it and spliced on a new wire that worked for a short while, and now there is no spark at all no matter what I do. What can I do to see if I missed something? Will I have to buy a new wire and fitting? This will cost over a 100 dollars to replace and if there is something that I am missing any advice would be greatly appreciated. I have replaced the spark plug as well 3 times with no luck...
Thanks!!!
You can check us out at sandpiper38.blogspot.com
Thanks!!!
