I ordered a complete seal kit for my Alpha one lower unit thinking it needed a shift shaft bushing and seal. After pulling the lower unit off I found oil coming out from under the water pump. When I took the pump off I noticed about 1/16 of an inch play up and down and side to side, in the pinion (input) shaft. I can pull up on the shaft and the tapered bearing seats and the play goes away. Does it need reshiming? There was no metal in the oil and it ran smooth the last time I ran it. I hate to put new seals in it only to have them torn up again. Anybody have any ideas on how much play in the pinion shaft is normal?
