  #1
Old April 3rd, 2009, 10:08 AM
Bob1954 Bob1954 is offline
Question Mercury 8 hp 2 stroke Impeller
I have a 2003 8 hp 2 stroke thats been sitting since 2003. I want to change the impeller. Can anyone walk me thru it? Any help would be greatly appricated.
Thanks , Bob
cerasoli@tds.net
  #2
Old April 3rd, 2009, 10:34 AM
Laddies Laddies is offline
Default Re: Mercury 8 hp 2 stroke Impeller
Disconnect the shift rod, under the carb port side, remove the 4 bolts the hold it to the mid section, drop the unit, remove the 2 bolts that hold the impeller cup on and change the impeller, then rev the process
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old April 24th, 2009, 10:08 AM
xjeepguy xjeepguy is offline
Hello Laddies
I'm looking at doing this on my 1990 8 HP Merc. I see where the shift rod is connected to under the carb , but there appears to be no screws , no cotter pins viewable to get the rod away from the part on the motor . Is there a trick I'm missing ?
Thanks in advance
XJ
Quote:
  #4
Old April 24th, 2009, 03:55 PM
emckelvy emckelvy is online now
The clip on the outside holds the shift rod in place. If you look carefully you'll notice it's slotted at the forward end.
With a screwdriver or other suitable implement, pry the clip upwards and as soon as it pivots off the part it locks into, you'll be able to pull it outwards and away from the shift linkage.
This frees up the shift rod so you can pull the lower unit.
One note, the little "shift cam" in the gearbox is threaded and the shift rod screws into it; be sure you don't spin the shift rod around while you're working on the lower unit, because that'll mess up your shift adjustment.
HTH...........ed
  #5
Old April 24th, 2009, 08:04 PM
Thanks kindly for the help . I was able to do all that and drop the leg and put it all back together . Issue LOL . No water peeing out of the pee hole now. I was doing the carb and a few other things at the same time , is it possible for the impeller to go in the wrong way , you know they way the impeller blades bend slightly when u put it in the cup ? When I fired it ,I seemed to have water pissing out from where the shift rod comes out from the lower leg . In that area. The picture below is the old one , looking from above when it goes into the leg , is that correct , in that direction ?
Thanks for any assistance .
  #6
Old April 24th, 2009, 10:48 PM
Update : Well after a long afternoon I took a break ,had a beer and a rest . Went and pulled the leg off again and I think while installing it the first time , while twisting the bottom leg to align the drive shaft I accidentally offset the tube where the water pushes to the top . I'm saying this in hopes that if someone else does this job here , to be real careful about aligning those two tubes together upon assembly of the leg . Now back to my carb woes .
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2003 2 stroke 90 hp impeller boatfund Mercury & Mariner Outboards 0 July 24th, 2008 09:47 PM
replace impeller mercury 4 stroke 9.9hp 2005 juke12box Mercury & Mariner Outboards 1 October 13th, 2007 02:49 AM
How easy is Impeller Repair Kit for 2004 Mercury 50 4 Stroke EFI? Bass-man Mercury & Mariner Outboards 0 June 23rd, 2006 11:18 PM
Mercury 4HP 2 stroke impeller change RSCaptain Mercury & Mariner Outboards 5 June 3rd, 2006 12:21 PM
1978 Mercury 4HP 2-stroke impeller change ant.mass Mercury & Mariner Outboards 1 June 3rd, 2006 11:23 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
