help removing transom mounting bolts
suwanneelonnie
i just got this 1982 merc.25hp one of the transom bolts was cut off and the other is striped out and frozen, whats the best way to remove them??? LONNIE
jmburock
Re: help removing transom mounting bolts
I would recommend an angle grinder, and If you don't have this, a second choice would be a Dremel with the high-speed metal cutting disks. A torch probably wouldn't be useful in this location as it would damage the transom. PB Blaster or similar probably won't cut it (unlike the angle grinder).
