  #1
Old April 1st, 2009, 11:47 AM
samm835 samm835 is offline
Send a message via AIM to samm835
Default Pontoon 2nd Battery set-up
I wasn't sure where this post should go, so let me start here and if I am wrong I hope it can be moved. I have been using for the last year or so on the lake a single battery. Well this year I am installing a new radio, and some other small things and I have always been a little scared about running the battery out on the lake. I have a 115 Mariner, so I was thinking there is already a spot for another battery to be held on the back of the toon. Is it easy to hook up a second? I know I should buy the switch that will allow me to use battery(1) or battery(2) or both. My questions is do I just get cables and run one battery to the other battery and then to the motor with the switch in the middle to have a choice to switch batteries? I don't want to over load my motor electrical or do any damage to anything. Thanks for the help.
  #2
Old April 1st, 2009, 12:26 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: Pontoon 2nd Battery set-up
You can use a simple switch to set up the batteries. There are other options that I'm sure others can advise you on..
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old April 1st, 2009, 06:06 PM
Silvertip Silvertip is offline
What that diagram does not show is that ALL of your accessories should be connected to the COM terminal. You can then run with the switch on BOTH so both are being charged. If you stop to fish or party for a long period you can switch to BAT 2 (if that's the house battery) so you don't run the risk of draining BAT 1 (the start battery). when you are ready to go, switch back to BOTH or BAT 1, start the engine, switch to BAT 2 to charge the house battery or BOTH. Follow the wiring instructions that come with the switch. Note that every cable in the system must be the same gauge or larger than the cable going to the engine.
  #4
Old April 1st, 2009, 08:07 PM
Jeep Man Jeep Man is offline
Following up on Silvertip's reply, It is also advisable not to charge both batteries at the same time if one is nearly fully charged and the other is low on charge. Batteries will take whatever power is available. If one is low, the charger will put out maximum charging power, possibly overcharging the other battery. Try to charge one at a time unless both batteries are close to the same level of charge.
  #5
Old April 1st, 2009, 08:33 PM
Mike722's Avatar
Mike722 Mike722 is offline
We had the same problem, but instead of installing a second battery I installed the volt meter so it is always on. This way I can monitor the battery when the key/engine is not on. We have a system disconnect at the battery for when the boat is going to set more then a day or two.
We don't set more then an hour or two without running the engine and the engine is easy starting. Your situation maybe different if you float/party for longer periods of time.
  #6
Old April 2nd, 2009, 12:06 AM
Voltage regulators monitor "system" voltage, not individual batteries in a dual battery system. If one battery is fully charged, the battery that is partially discharged will suck current for the full battery until they are both equal. During the charging cycle if the regulator senses normal voltage it will regulate accordingly. There are many trucks, cars, and boats running dual battery systems, they don't have a switch so both are charged at the same time and the system works just fine. That is exactly why the switch has a BOTH setting - so you can start on both or charge both. If you did happen to run a single battery very deeply, set the switch to that battery so that 100% of available power goes to that battery. It will not harm the charging system to run on BOTH. If it did, you would see law suits up the ying yang.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2nd Battery Help dgs119 Electrics, Electronics and Trolling Motors 1 March 8th, 2009 06:29 PM
2nd battery stevecut Force & Chrysler Outboards 2 July 7th, 2006 08:54 PM
2nd battery connection cthru1 Yamaha & Suzuki Outboards 5 January 30th, 2005 01:34 PM
2nd battery hook up? teamstromer Boat Topics and Questions (not engine topics) 5 May 30th, 2004 08:39 AM
2nd battery hook up? teamstromer Non-Repair Outboard Discussions 2 May 26th, 2004 06:49 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
