Re: Evinrude 150 stopping at low RPMs
Champion Plugs. true, a lot of trolling, open gap an additional .005 or .010.
150, 175 (60º V6) 1991 & newer QL78YC (see note 3) .030
150 Commercial (60º V6) 1993 - 2001 QL78YC (see note 3) .030
also make sure you low speed jets are clean. the bulb is suppose to be soft once the fuel pump starts pumping.
charging voltage has nothing to do, with the running voltage. the motor runs off the stator, not the battery.
you need separate, house batteries to run your electronics and accessories. you can install a battery selector switch, to charge the house battery, when running fast. post the battery switch question in the electrical forum.
the motor puts out, little charge running at idle speeds.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
