chillin014
- Jan 14, 2009
- 91
I'm trying to change my impeller on my 1990 50 horse Force. So I remove the lower and upper gear housing together along with the drive shaft as shown in the Force manual I have. I should be able to "lift" the drive shaft straight out after loosening the waterpump housing but it will NOT come out. Its has play in it, wiggles up and down about half an inch but it simply wont come out any further. I started trying to remove the propeller and lower gear housing to try to get at it from that end but I cant seem to separate the lower gear housing from the upper. I have tried everything I can think of...is this common? What is the problem? I have been jiggling and shifting the clutch with the shifter rod and everything with no luck.
please help...I'm afraid to get too aggressive with it and break something expensive.
I'm thinking the driveshaft just must be seized in where it connects on the bottom...maybe I will try to squirt some anti-seize stuff and just try forcing it..
