tswiczko
Master Chief Petty Officer
- Feb 15, 2009
- 838
I recently bought an old Mach 1 and done some maint to get it on the water. The first few times on the water were ok but I started to get a vibration in the floor and can reduce the vibration by triming the out drive but is still there. I removed the magnetic plug to find fine metal shavings and feel a faint bump when turning the prop by hand I have been ocd about keeping the drive full checking it every time I go out and it doesn,t leak and the lube looks the same as the day i put it in should i pull it or run it till it gets worse.
