  #1
Old March 30th, 2009, 07:58 PM
mikejan mikejan is offline
Default Fishing in a Pontoon Boat
I like to fish. My wife doesn't particularly like the typical fishing boat that I have used in the past--16 ft aluminum boat/52 inch bottom/40 hp motor; low sides and no amnenities like soft seats etc. Makes me wonder about the possibility of trying a pontoon boat.
Two problems:
1) I understand that these types of boats can porpoise in choppy water? Is there a resolution to this tendancy?
2) Sometimes I motor/fish in two feet of water. Can a jackplate be used to allow for shallow water fishing?
Thanks, Mike
  #2
Old March 30th, 2009, 08:20 PM
rrhodes's Avatar
rrhodes rrhodes is offline
Default Re: Fishing in a Pontoon Boat
My triple log pontoon handles chop better than most V-Hull boats. Not that I think it is a good choice for offshore but for Lake fishing I would not trade it for the world. Last July we had a serious storm hit our lake on July 4th. I was running through the chop at WOT (27-28mph) While other boats were getting beat up and cruising back at low speed.
For shallow water fishing I would use a trolling motor although the draft is not much different for a V-Hull boat. My toon's draft is about 20" Of course that various Slightly with load. I have trolled in 2 feet of water (Pucker factor was high when I realized that on my depth gauge)
__________________
Rick
2008 JC Neptoon 25TT
115hp Honda 4-stroke
2007 Suburban LTZ
Lake Murray, SC
  #3
Old March 30th, 2009, 09:07 PM
Silvertip Silvertip is online now
A pontoon makes an excellent fishing rig but you need a fishing setup. I have a Misty Harbor 4-corner fish as they are called. Most pontoons are not set up with a live well so this is a must for serious fishing. Miine has a fishing seat in each corner and the rails are a bit lower in those positions but normal height at the center. It has a 55# Minnkota Power Drive V2 trolling motor up front and it will sneak into some pretty skinny water. Extremely comfortable and the bimini gives you some shade on those really hot days. If you have smaller kids with you I would avoid the pontoons that have the front deck open with no railing. There is nothing to hang onto and kids (and less stable adults) could easily fall off.
  #4
Old March 30th, 2009, 11:36 PM
Gentlemen:
How many inches does your pontoon boat draft with the motor up?
Thanks, Mike
  #5
Old March 30th, 2009, 11:54 PM
rrhodes's Avatar
I am honestly not sure but the logs on my JC are only 24" tall so I would assume 12 - 16 inch max.
__________________
Rick
2007 Suburban LTZ
Lake Murray, SC
  #6
Old March 31st, 2009, 07:38 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
according to the water line on mine about 12 inches, and i can leave the motor down, as my foot is above the bottom of the tubes. mine is set up for cruising and fishing. also notice the water line, these are 22 diameter inch tubes.
my motor is a long shaft, so i had to raise it.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #7
Old March 31st, 2009, 08:26 AM
Jeff Walkowiak's Avatar
Jeff Walkowiak Jeff Walkowiak is offline
that's all I use mine for ,I'm going fishing today actually best flats boat I ever had. made the bait well from a low boy cooler with a pump to feed it and a pick up tube for when the boat is moving,, all is easily removable but I never take it off. I mounted plastic boxes in the rear,, used insulating foam in one so I have a fish box that holds ice and fish for 24 hours.
__________________
owner and inventor of cobra jet steering us patents 6561858 and 6702630,,
and cobraezlock for yamaha jet boat clean out plugs.
I just keep getting older but not wiser,, what's up with that?
  #8
Old March 31st, 2009, 11:24 PM
Thanks for all of your replies. Regards.
  #9
Old April 1st, 2009, 12:11 AM
boatmor boatmor is offline
I wouldn't have anything but a toon for fishing- once you try it you will be hooked and the wife sure won't let you get rid of it.
I took my 20 footer to Truman lake on the windyest, roughest day I could to test it on rough water. I drove it at every speed and direction possible and it handled like a charm. I can't imagine a better boat for rough water.
I like to take all the furniture off and use fishing seats on movable bases so I can set them wherever I want. I use a desk chair for driving. It is cloth covered and blue so it won't be as hot as a black one. It rocks, swivels, goes up and down and I left the wheels on it. They don't bother anything and are handy to move around with. I love it. I use an ice chest instead of a live well. much less hassle and the fish are dead and cold so they are easier to clean.
I've had a 28 footer, an 18 and now a 20 plus my daughter has a 24 footer so I have got to try them all out for fishing and camping. I am going back to an 18 foot as it is easier to get around in, drives about like a car.
Of course you need to buy a boat according to what you want to do with it. Number one is don't overload them as you lose all performance. My 28 footer ran faster than the 18 footer with the same motor on it because it floated higher in the water.
I intend to get an 18 footer with 3 logs as they perform better and of course without furniture.
I also intend to get the high fence all around as I am old and clumsy and love to fish in rough water.
http://picasaweb.google.com/shootmor/Pontoon02#
  #10
Old April 2nd, 2009, 07:54 PM
To Boatmor and others:
Who makes an 18 ft, 3 log pontoon for fishing?
Thanks, Mike
  #11
Old April 2nd, 2009, 11:58 PM
OldePharte's Avatar
OldePharte OldePharte is offline
Thanks, Mike
Voyager makes a center console unit. 3rd log is an option. See - http://www.voyagerboats.net/pontoons...6&type=fishing
G3 makes one as well - http://www.g3boats.com/SunCatcher/LX22FC/
No doubt, there are others.
__________________
2009 Neptoon 25TT Sport Sun Lounger
150 Honda
I don't skinny dip . . . . I chunky dunk
  #12
Old April 3rd, 2009, 06:53 AM
5150abf's Avatar
5150abf 5150abf is offline
I don't think you could get a pontoon to porpoise if I paid you so whoever told you that was very mistaken.
I agree, I don't think you will find any boat that rides nicer than a toon, I have had one of our company boats up to 47 in a 3' chop and it didn't even fizz up my pop.
If you step up to a 20' boat you will really open up your options, 18' tris are pretty rare but almost any company offers a 20 tri and in fishing trim and they are pretty close in price.
At the bottom of the main forum the have all the pontoon manufacturers listed and it takes you right to there site so you can compare boats, just check to see if they are still in business, the last year has been very hard on the boating industry and we have lost alot of manufacturers.
__________________
GO IRISH!!!!
  #13
Old April 3rd, 2009, 11:43 AM
OldePharte's Avatar
Quote:
Originally Posted by 5150abf View Post
I don't think you could get a pontoon to porpoise if I paid you so whoever told you that was very mistaken. SNIP
The only time that I have seen a pontoon porpoising was when it was trying to hit 65+ mph. Not a normal occurrence.
There is/was a youtube video of a pontoon up for sale making a high speed run to impress the potential buyer. That and watching our lake's top gun shootout where a pontoon was doing 80+ mph, with just a slight amount of porpoising.
__________________
150 Honda
  #14
Old April 3rd, 2009, 01:00 PM
rrhodes's Avatar
Maybe what he meant was the submarine effect. I have seen toons catch a wave and submarine before. It was a 2 log older toon.
__________________
Rick
2007 Suburban LTZ
Lake Murray, SC
  #15
Old April 3rd, 2009, 07:57 PM
OldePharte's Avatar
Quote:
Could be. Heck I've done that before. Just keep the weight towards the rear, watch the speed, and watch the waves. Which is one reason I am trying to go to a 26 footer to minimize our wakes that are generated by 60 foot cruisers plowing down the lake.
__________________
150 Honda
  #16
Old April 3rd, 2009, 09:12 PM
Thanks for all the info guys. This is a tremendous resource.
I was referring to submarining instead of porpoising. Thanks, again.
  #17
Old April 3rd, 2009, 11:26 PM
Most of the submarining was with older toons with small tubes especially when loaded. It doesn't amount to anything except the danger of throwing someone over the front of the boat then running over them. It does get folks excited.
Voyager will make anything you want and they are good boats and good folks.
  #18
Old April 3rd, 2009, 11:54 PM
rrhodes's Avatar
I have seen some newer toons do this as well. Most of the time it is due to running WOT throttle with too many people in the front of the boat and crossing a wake. As far as amounting to nothing I disagree. The toon can go from 30mph to 0 very fast which will sends it's passengers flying forward as 30mph.... This is harder to do with a modern 3 log toon but not impossible. Another danger is if the driver does not kill the throttle the motor can and will continue to push the deck under water and as you said driving over anyone that was thrown forward.
This scenario is unlikely but possible. Boats are a lot of fun but never forget the danger as well. When you are captain of your boat all the passengers are your responsibility.
__________________
Rick
2007 Suburban LTZ
Lake Murray, SC
  #19
Old April 4th, 2009, 07:37 AM
5150abf's Avatar
I subbed the last company boat I had out and it was a 25'' I/O top deck with the ESP which makes the boat bank in turns, I was screwing around doing tight turns an spun it 180 then cut throttle and was quite suprised when my wake came over the deck, other than some wet carpet, no harm done.
It was a hoot having a 25' top deck pontoon banked way over cutting a hard turn, wouldn't think they would even do that.
__________________
GO IRISH!!!!
  #20
Old April 6th, 2009, 08:14 PM
ozarkglen ozarkglen is offline
Smile Re: Fishing in a Pontoon Boat
I have the very same problem with my wife. She loves the lake, but hates to fish. I have had two bass boats and could rarely get her to go with me. She convinced me to try a pontoon, and we never looked back. Now we go to the lake nearly every weekend and both have a blast. My 18' Lowe has 2 livewells and a trolling motor. The fishing seats are up front, so while I'm fishing she is in the back enjoying her book or floating on a raft tied to the back. Now we both can do what we love at the lake on the same boat and at the same time!!
  #21
Old April 9th, 2009, 09:58 AM
Rancherlee Rancherlee is offline
I bought an older 20ft. pontoon and moved the rear furniture forward which allowed be to mount 2 fishing seats in the back, Works GREAT. I have fishing seats in all 4 corners and with removable posts I also made up a mount for a small BBQ that pops in the seat mount. A 20 footer is perfect size for smaller family and does OK with 4 adults and 3 kids but is kinda cramped for fishing (Mine only has a 8x17 deck). I didn't think I would like a pontoon but now my 16' fishing boat just sits behind the garage. I also did the same "cooler" livewell setup that someone else showed above.
  #22
Old April 9th, 2009, 01:34 PM
pontoonokie pontoonokie is offline
this is my first post and i dont want to hijack this thread .. but i was wondering if there is any special fitting need to make a cooler/livewell/bait box.. and thanks for all the great info so far.. this is my first pontoon .. and i am exctied..
  #23
Old April 9th, 2009, 06:53 PM
5150abf's Avatar
Feel free to start a new post and stick around and see if you can help others with what you learn on the water.
Poke around in the iboats store, I have seen kits that let you do that and they include everything you need, if you can't find it here then i knwo I have sen them in Cabellas.
What kind of toon did you get?
__________________
GO IRISH!!!!
  #24
Old April 11th, 2009, 12:13 AM
Thumbs up Re: Fishing in a Pontoon Boat
thanks... i'll do that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
pontoon fishing seats duck64 Boat Topics and Questions (not engine topics) 2 August 1st, 2009 06:16 AM
Pontoon Boat - Water Glide 3rd Pontoon martybhawk Pontoons 7 July 13th, 2008 11:09 AM
pontoon fishing boat rant Devious Dockside Chat 10 June 10th, 2008 10:19 PM
looking for a fishing pontoon boat Larryc5079 Boat Topics and Questions (not engine topics) 4 October 10th, 2007 09:45 PM
Pontoon Boat - Recommendations (Fishing Type) GunRunner Boat Topics and Questions (not engine topics) 0 March 11th, 2001 11:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
