  #1
Old March 30th, 2009, 03:18 PM
C-worthy C-worthy is offline
Default Mercury gas tank for a Johnson?
Hi,
I have a new-to-me 1978 Johnson 6 hp I bought without a gas tank. I have two gas tanks available: a big Evinrude Cruise-a-day tank and a 2.5 gallon Mercury tank. I like the Mercury tank's size and can easily adapt the hose to connect to the Johnson motor.
I've read about Cruise-a-day tanks being "pressurized" though. What does that mean? Unlike the Mercury tank, the connector on the Cruise-a-day tank has two spring-loaded pins and doesn't seem to have a vent. Do the spring-loaded pins on the Cruise-a-day have to do with venting? Can I use either of these tanks with the Johnson motor?
Thanks,
Brian
  #2
Old March 30th, 2009, 03:23 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Mercury gas tank for a Johnson?
cruse a day is for 1950's motors, the tank is considered valuable, up to 100 if in good shape, it will not work with your motor, a tank is a tank, just need the primer blub, and the correct end fittings, i have used several merc tanks on J/E's.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old March 30th, 2009, 05:57 PM
wbeaton's Avatar
wbeaton wbeaton is offline
The Evinrude tank is absolutely no good to you. Sell it or buy a 1950's Johnson/Evinrude and use it.
__________________
Wayne
  #4
Old April 1st, 2009, 03:19 PM
Thanks both of you for the answers. I'm not trying to belabor the question, just trying to learn.
The fuel connector from the '78 Johnson clicks onto this Cruis-a-day tank connector. How did you conclude the tank is not compatible with the '78 motor, is from the 50's instead, and may be valuable? (I hope you're right about that).
I see a lot of Cruis-a-day tanks on e-bay for much less than $100. What would I look for in a 1978 tank that's different from what I have?
Thanks again
Brian
  #5
Old April 1st, 2009, 03:51 PM
reelfishin reelfishin is offline
Does your Cruise A Day tank have a pump on it and a return line?
I've seen quite a few tanks marked Evinrude Cruise A Day that weren't pressure tanks. I've always just figured that they called all of them Cruise A Day back then? My two 1958 FD-12 motors with pressure tanks do not say Cruise A Day on the side though.
Here's one I found on line which may be what the OP has:
http://i41.tinypic.com/2emfzvs.jpg
  #6
Old April 1st, 2009, 05:01 PM
idrownworms's Avatar
idrownworms idrownworms is offline
The tank we have for our maroon 71/2 is pressurized and does not a quick connect on the tank side the double fuel line is attached to the tank. The pressurized tank also has a threaded gas cap instead of the quarter turn bayonet type of the new style.
jamie
__________________
Endeavor to persevere
What happens in the event horizon stays in the event horizon
  #7
Old April 1st, 2009, 05:08 PM
does the cruise a day have 3 pins, 2 lines and a pin that holds the clip. if so that is a pressurized tank. you pump the button and that forces gas to the motor thur the gas line, when the motor starts it sends air into the tank, by the air line, forcing gas to the motor.
the 6 hp only has one fuel line, the connector has a line connection and the clamp pin. the motor has a fuel pump that sucks gas from the tank, the vent on the tank has to be open for the motor to suck gas.
__________________
FLORIDA GATORS
TEBOW Country
  #8
Old April 1st, 2009, 05:15 PM
Yes, it looks a lot like that photo except the hose connection/pick-up is mounted at 45 degrees to the axis of the tank, the label paint is mostly scratched off and one of the tabs for winding the hose around is missing. On the plus side, it's nice and clean inside.
It doesn't have hoses or pump of it's own so it sounds like a run-of-the-mill $10 - $20 tank.
Brian
  #9
Old April 1st, 2009, 05:17 PM
I need to figure out how to post a picture of the connection on this tank.
  #10
Old April 1st, 2009, 05:52 PM
wbeaton's Avatar
I think you threw us when you mentioned that it might be a pressure tank. A good pressure tank will run between $30-100. Cruis-a-day is just an Evinrude trademark. If the fuel line connector fits your 1978 then its not a pressure tank. Does one of the prongs on the fuel connector have a spring loaded pin in it and the other is of a larger size? If so then you have an ordinary vented tank. It will work with the 1978. If the tank has a silver plunger or black button on top, a three prong fuel connector and a double line hose then you have a pressure tank. I suspect you don't have a pressure tank now that I've reread your post.
__________________
Wayne
  #11
Old April 3rd, 2009, 02:31 PM
I still didn't get a picture taken but here is a description of the connection on the tank:
It has FIVE pins, not four as I thought.
Pin #1 is solid, about 3/4" long by 3/16" diameter, it has a groove and a tapered arrow point end. The '78 connector clips onto the groove on this pin.
Pin #2 is solid, about 3/4" long by 3/16" diameter, no grooves, I didn't see any holes and the end is straight with no taper or arrow point.
Pin #3 is hollow, shorter and about 3/16" diameter, with holes in it, presumably for the fuel.
Pins #4 & #5 are very small and the same, side-by-side, maybe 5/16" long and 1/16" diameter, these two are spring-loaded.
It also has a cork float on a rod for the clear glass gauge. Does this sound like a pressure tank or an ordinary tank? Why so many pins? Do all these pins mean anything unique about it's age or use?
Thanks again for having patience with a newguy!
  #12
Old April 5th, 2009, 01:53 AM
Gonna need a pic for that one then.
There were some tanks made which had separate oil tanks built in, there was also one that premixed the fuel. Post a pic so someone can ID that tank and fitting.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
vent on gas tank question (in hull tank) not gas can naphobia Force & Chrysler Outboards 3 July 17th, 2008 10:59 PM
Mercury 25 Gas Tank Connection bermuda8 Mercury & Mariner Outboards 2 June 23rd, 2007 02:53 PM
What off the shelf aerosol would be closest to Mercury gas tank red? John Reynolds Mercury & Mariner Outboards 0 May 28th, 2003 05:25 AM
84 Mercury gas tank Wide_One Mercury & Mariner Outboards 9 March 18th, 2003 07:25 AM
Mercury Gas Tank Petrajn Mercury & Mariner Outboards 1 July 15th, 2001 03:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
