I'm purchasing a 20' Celebrity with a Mercruiser 260 Alpha one inboard it has 615 hours it is a project to me the bottoms pretty crusty that's not a problem to me. But the 615 hours seems like a lot . I am mechanically inclined it seems I was assuming even if it runs which it is winterized it will need a rebuild, What I wanted to know what can I expect in the neighborhood of hours can be gotten out of this motor, and what should immediately should be done to it. the owner said he did rebuild the outdrive and gimble bearing two years ago. I was looking for where you can purchase inexpensive engine rebuild kits or can this be replaced with a regular Chevy 305 car motor I am purchasing this package for around a thousand dollars so I figure I cant go wrong. I just didn't want to spend like four thousand or an engine any suggestions t
thank you
thank you
