Today i went to start my outboard, a 88 115 merc..I have gas coming out the front of all 3 carbs!! It happens only when i pump it..I also have the motor tilted alittle.. I did a search and saw it could be a stuck float..But i can't see all three being stuck.. Will it make a difference if the motor is all the way down? I was thinking if it is tilted up alittle the floats are up also!!!
It will just kick over, it wont stay running, i guess its cause all of the gas is going out the front!!
Should i always keep the motor all the way down when going to start it?
Also is starting fluid ok to spray in there to help get her started?
Any help? Laddies?
Any help? Laddies?
