How big is your boats tank
puddle jumper
I was at the Chevron bulk plant yesterday. One of the off shore coastguard vessels were in getting fuel at there marine fuel dock. The plant called in one person for 5 hours to fill 600,000 litter tank. Apparently they just filled up 2 weeks ago. Can you imagine 5 hours and 600,000 litters later to fill you boat tank. Yikes:eek:
slasmith1
Re: How big is your boats tank
Wow I only hold 210 gallons(795 liters) and I cry when I fill up.
wuttja
If it's around $2.25/gallon (US) that would be around $356,630 USD. Glad that isn't my fuel bill. 42 gallons (159 liters) is more than enough to fill up for me!!
derekpfeiffer
My new boat has a 35gal fuel tank....when I bought the boat I thought it seemed a little small...but after using the boat for several months last summer it amazed me how economical the 350 MAG MPI is on gas!! Very comparable to the consumption that I was seeing out of my 4.3 v6 carbed!!!
xxturbowesxx
I have 2 14 gallon tanks wish I had more with a 150hp.
SS MAYFLOAT
Mine holds 100 gallon. I put 70 in it and it lasts me the season. Whats left I use in the snow blower and log splitter thru the winter.
zach103
19 gallon permanent still gotta get the hose for it so right now 2 6gallons portables..
frankie g
101 gals. I use about 80 gals per off shore trip, probley 6 x's a yr, and inshore trips about 40 gals per trip...approx. 8 x's a yr. some where between 700 - 750 gals per 12 months of fishing and boating.
Reel Poor
185 gallons and a typical day of cruising we'll burn 60 to 70 gallons. I'm not much of an anchor boater. I like to ride. :)
BWR1953
My 22 footer has a 75 gallon tank, which will eventually feed a pair of 115hp Mercury outboards.
The 15 footer currently has a 6 gallon portable, but I did buy an 8.7 gallon belowdecks tank that I'll install for use with the 7.5hp Evinrude. Later, that tank will be replaced with something in the 13-18 gallon range when I move up to bigger motors on the little boat.
-BWR
david_r
i wish i had a big tank. i was using 2-- 6 gal portable tanks.........stolen from my little boats. now i have a 12gal and keep it full along with a 5 gal for reserve.....so my little boats are functional again.
eaglejim
2, 6 gallon tanks when gas was expensive I was glad that I didn't have a bigger tank :D
puddle jumper
My own boat has a 25 gallon tank and it hurts when i fill it on a weekly basses.
Shizzy
Ensign
3 gallon! lasts all weekend with the little 6HP :p
mphy98
20 gals and thats enough for a couple of days fishing at least
chicknwing
2 six gallon tanks with a 17 gallon to be installed this spring.
TC
Nandy
I have 2 6 gal tanks. Which I used in the old boat (Babcock) and now transfer to the "new to me" Cobia. Last season was the first year using this Cobia boat combo and due to my economic problems and the price of gas I never really got to use it as I wanted. Looking to maybe get me 2 12 gal tanks... not sure yet...
mthieme
Sea Ray - 26 gallons. Typically only use about 5 gallons unless I go somewhere across the bay. Then all bets are off.
McKee - 2 x 6 gallon tanks. Might go through one playing on the river all day. 3-4 gallons crabbing.
Hydroplane - 3 gallon tank and 1 gallon reserve. I have 1 hour 40 minutes of run time. That reminds me - gotta replace the battery in my watch.:)
I counted up the gas engines the other day - 13 total. Batteries were more than twice that. I gotta thin the herd...too many tractors!:)
