  #1
Old March 29th, 2009, 07:37 PM
happymotor1 happymotor1 is offline
Default 225hp 2004 Mercury Optimax Stalling Problems
Help,My Optimax 225h(2004) is having problems which no one seems to be able to fix.
My engine runs fine at anything over 1000 rpms. When at idle tied to the dock the engine stutters and eventually stalls.
The last repair person had me change to the Hgiher grade Mercury Oil and use a better grade of gas thinking that the exhast system was clogged with sludge and that this change would clear up the problem. I started this last November. I did this for a couple months and there was no change.
Last month he said and showed me that when the engine is tilted up a little,
the stuttering stops and the engine appears to run fine. When the engine is trimmed down that exhast would would eventually come out of the prop hub and it was at this point that the engine would start running poorly and eventualy stall.
This has been going on a long time. Over 12 months. Plugs changed twice. No effect. Compression tested OK. 580 hours on engine.
I am a 2 time Mercury owner and I am becoming very unhappy.
Any idea's?
  #2
Old April 1st, 2009, 10:02 PM
Langpie Langpie is offline
Default Re: 225hp 2004 Mercury Optimax Stalling Problems
I am having pretty much the same problem on my 2004 Mercury Saltwater series. It will stall at idle or just in gear but underway she runs like a champ. I noticed while on the trailer at home flushing the engine it will run fine at idle and never stalls. So if someone replies to my thread about my problem ill post it on urs. Good Luck
  #3
Old April 12th, 2009, 09:29 PM
Langpie, I spoke with Mercury. They told me to use a triple gas treatment of Quick Cleen. I am still in the process of running over 100 gallons. Will keep you posted. I am now noticing a surging power at idle.
  #4
Old May 21st, 2009, 07:21 PM
Langpie,
I believe my engine is fixed. I willl test this weekend. I had a Mercury service company look at it. He said there was a hole in the diaphram between the fuel and air pressure.
I have listed a response below that I got from an earlier thread. The problem was that I didn't know what "woody66912" was talking about. I should have gave his reponse to the last guy servicing the motor.
woody66912
Re: 2004 225 Optimax Problems
I'm not sure what was all looked at already.but when optis have idle problems i always check the flowing /fuel lift pump diaphragm / witch would let raw fuel into the engine block. [air] side of fuel rails for excessive fuel in the air side.witch would indicate a failed tracker valve or fuel pressure regulator diaphragm.also the air handler on the front of the engine can be removed to check the reed valves for cracks or chips.not sure if any of this helps.
__________________
don't claim to know it all just hear to help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2004 225 Optimax Problems wantahappymotor Mercury & Mariner Outboards 4 May 21st, 2009 07:29 PM
2004 Mercury Optimax -225HP cheeseburger Mercury & Mariner Outboards 10 February 20th, 2009 09:01 PM
decals for a 2000 225hp mercury optimax gloveman Mercury & Mariner Outboards 3 April 7th, 2008 08:45 PM
2004 Mercury 115 optimax stranack@tpg.com.au Mercury & Mariner Outboards 1 December 13th, 2007 04:17 PM
Mercury Optimax 225hp DTS qmmaster Non-Repair Outboard Discussions 0 November 16th, 2003 02:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
